I've got a Naomi 1 motherboard on the bench that runs as I have audio but doesn't output video, I've tried swapping the 315-6145 dac with a few from junk boards thinking that would be it, as it seems to be a fairly common failure. After that didn't work I did some tracing and found some shorted diodes connected to the rgb and sync lines, after replacing these I get h/v sync at the vga port but the rgb lines are low, too low for my monitor to accept (about 0.8v).
Looking at the dreamcast schematics the circuit looks the same and I've also ruled out the three caps connected to rgb lines and the three 75ohm resistors, I've also tried a different known working filter board which made no difference.
It's possible this was a F355 board originally as it's an early one I was thinking maybe the video output was never used and I am missing some factory bodge wires?
I found this image used for the hdmi instructions and noticed some bodge wires which mine doesn't have, but I am clutching at straws now. Anyone seen this issue before?
