davkilik
France
Hi all,
Remote with Extended Menu fo New net city and Egret 3
Remote boards with Extended Menu for New Net City and Egret 3 with Toshiba chassis only.
It allows to set geometry, colorimetry and high contrast mode to fine tune the picture which is impossible with the original remote.
As you can see, it fits like a glove in place of the original one, it's just a matter of removing and replacing two screws and reattach cable.
Asking 35 euros per board.
Remote Sanwa PFX Extended menu
Remote for Sanwa PFX turntable with the possiblity of activating the service mode ( Extended menu ).
The Pcb was designed to mount in Naomi or New Net City Arcade cabinet.
Original remote:
Remote with extended menu :
Two washers are required for perfact assembly ( included ).
To enable service mode, you must set the red dipswitch to ON and turn on arcade cabinet. Once arcade cabinet is turneed on, return the dipswitch to OFF in order to be able to navigate in the menu.
Asking 30 euros per board.
Repro remote Nanao MS2932 ( Naomi Cabinet)
Asking 50 euros per board.
Repro remote Sanwa 29E31S (Naomi Cabinet)
Repro remote Nanao MS9-29 (New Astro City Cabinet)
Repro remote Nanao MS8-29 (Astro City Cabinet) and compatible with Ms8-25
Original
Reproduction
Repro remote Nanao MS29-31 ( Blast City Cabinet with automatic chassis )
Asking 25 euros per board.
Repro remote Nanao MS29-30 (Blast City Cabinet with manual chassis)
VGA connector for New Net City tri-freq Toshiba chassis
Same as the original.
Cable provided.
Asking 28 euros per board.
