hello I have a console setup on a tv that has component. I run everything through 2 scart switches with auto port that go through a rgb2component to the tv. My question is what would the best way to hook up HAS to my setup?
The only issue you may end up with some PCBs not syncing up with the TV (like Raiden PCB).thats it? I was thinking it would require more that seems easy. I thought i might need to incorporate an extron or ossc or something
I don't think you can. You only option is to tweak via service menu.what can I add to the chain to fix sync and geometry
