hrvat9
Mississauga, Ontario, canada
Looking for the values for :
R202
C205
Edit : just noticed c205 is the brown cap beside it since it has the square on the board; 154J , how do you interpret that ?
They were missing because of corrosion
Just noticed online that these two aren’t populated (I think on all motherboards). Mine must of just looked like something fell off from the corrosion , since it raised the solder up
M92 cap list (excluding 154J):
C201 1uF 50V
C202 470 uF 25V
C203 220uF 10V
C204 22uF 25V
C209 100uF 25V
C210 1uF 50V
C213 47uF 16V
C215 1uF 50V
C216 1uF 50V
C217 1uF 50V
C218 1uF 50V
C219 1uF 50V
C236 100uF 25V
  • R201 – 1KOhm
  • R203 – 100KOhm
  • R205 – 4.7KOhm
  • R208 – 4.7KOhm
  • R209 – 2.7KOhm
  • R211 – 10KOhm
  • R213 – 10KOhm
I appreciate that this doesn't answer your question, but thought this info might be useful at a later date ;)
Thanks! Got it recapped and now my picture is stable and theres deafening radio silence instead of squealing :) I also got a funky colour problem
C201 1uF 50V
C202 470 uF 25V
C203 220uF 10V
C204 22uF 25V
C209 100uF 25V
C210 1uF 50V
C213 47uF 16V
C215 1uF 50V
C216 1uF 50V
C217 1uF 50V
C218 1uF 50V
C219 1uF 50V
C236 100uF 25V
  • R201 – 1KOhm
  • R203 – 100KOhm
  • R205 – 4.7KOhm
  • R208 – 4.7KOhm
  • R209 – 2.7KOhm
  • R211 – 10KOhm
  • R213 – 10KOhm
Reseating ics on the b board; one had a pin bent back and not going into the socket (this changed nothing when corrected) and the one mask rom has the ground (?) pin broken clean off. would that mask rom be for sound or for something to do with my colour issue?
C-Roms are for GFX tiles, so that would account for graphic issues. Does the problem change when running the board without that mask rom?
Good call, yeah It does change similarly but a lot worse with the whiting effect. The grinding pen is coming out first to see if I can reveal this busted leg🦵
Pin fixed but it didn’t make any difference.
I also noticed this little guy is busted and a pin is gone from this 7474; is that normal on m92s?
