Where to buy a Neo Geo 1FS CR2032 battery kit from?
just buy a simple coin battery holder and a cr2032. You can get them from amazon or ebay cheaply. Or go over to console5 and pick them up.
The battery on Neo motherboards is rechargeable - do not, I repeat: DO NOT install a non rechargeable CR2032 onto a Neo motherboard without first disabling the recharge circuit by removing the resistor next to the battery (there are pictures to point this out, I don't have one on my phone)
If you install a non rechargeable battery and leave the charging circuit active, it will heat up and explode and completely destroy your Neo board or worse if you're anywhere near it
You can get the rechargeable CR2032 batteries from specialist battery suppliers, Element14/Farnell, RS etc
Such as this:
http://au.element14.com/maxell/ml-2032-t17/button-cell-r-c-pcb-2032-3v/dp/3031998
Thanks for the replies.
I didn't know you could just use a standard one.
And yes, I would disable the recharging circuit.
:D
