Hello all, finally got around to having a full session with my CPS3 board playing 3s yesterday and found some sort of intermittent issues. First, the sound works sometimes and sometimes will cut out. Switching audio from external to JAMMA and back fixes for a while but then it dies again. Using external audio in general works for a while, but then one of the channels will suddenly die out and stay that way until I have the power off for a bit. To me it feels like a heat issue and an amp going bad, but I'm not sure where to start on fixing it. Any ideas on what I should change out in the area? I see several caps around there that are perilously bent/loose, so that may be a place to start.
Second issue is that there is some bowing in the center of the screen like the geometry on my cab is bad. After we switched games to something else rather than deal with the sound issues, I swapped my CPS2 into the cab. Sound works great first try and there's no geometry issues. Where should I start with trying to troubleshoot this CPS3 board?
Thanks in advance for your help!
