Thrillhouse
STL, MO, USA
I'm looking at a Willow boardset for a local collector. The game plays fine and seems to sound fine, but has some pretty severe graphic and letter issues. Many graphics (static and moving, not sure if every component is considered a sprite) are missing layers or colors. Letters are all rendered correctly, but have the wrong colors. The game passes self tests and does show that all colors are present within the service menu. I'll attach a couple pics of the issues I'm seeing.
My troubleshooting process has been as follows:
-Reseated A, B, and C boards. No bent pins, connections feel solid.
-Verified voltages between the PSU and B board. Tested in two different jamma cabs - no difference.
-Tested with a known working A board - no change.
-Tested a known working B and C board on the Willow A board - no issues.
At this point, It's definitely something on the B or C board.
-Reseated and cleaned the pins on every socketed chip on the B board. No change.
Ideas? Perhaps a corrupt ROM?
Dump the ROMs and compare the checksums with MAME. Very likely one or more of them is corrupt.
Check the custom resistor/diode arrays (DAx) near the top-left of the PCB. Sometimes they short when they die. You may notice one of the three 74LS245s is a lot hotter than usual as a result.
It is also possible your willow C board is no good. To a degree you can test with other C boards, if available.
I'll dump and check the roms tonight for sure.
Will check components in the top-left as well. I haven't done a ton of research on C boards - the only other C board I have is from a Street Fighter II. Not sure if that would be reasonably compatible for testing or not.
My money is on the C-board, that's why @undamned 's work is so interesting...
We should be able to turn the b-21 C-board into any other C-board.
I just thumbed through that thread - very interesting! This is the first CPS1 board I've worked on, but I'm familiar with UD's CPS2 infinikey.
Willow runs with CPS-B-03 on the C board, so there are no immediate donors. Modifying the game code to run on another is not a large undertaking, or configuring a CPS-B-21 to use a custom configuration would also be possible. As it stands now, no existing CPS-B-21 combination matches CPS-B-03.
This. Looking at the above images that's either A or C custom. You've confirmed the A is good, that leaves the C :(
I had 3 Final Fights and a Captain Commando recently all with similar or worse faults, all C board related.
I sent an InfiniKey CPS1 proto to Parodius to do some testing and he was able to use his battery B21 as a B03 replacement with my board.
-ud
I sent an InfiniKey CPS1 proto to Parodius to do some testing and he was able to use his battery B21 as a B03 replacement with my board.-ud
That's great news - does that mean the full meaning of the bitstream is understood, rather than being copies of existing configurations?
Pretty much. Back when Ed had finished his B21 research, he made a youtube video that breaks it down.
-ud
