Mind letting me know what cap kit or caps needed for this?
sure. i make a list which caps were in mine. there are two parts basically one is the Sound (bellow) and the other is the top part for power.
Here is the list for the sound board
Nvs 4000 sound board
Two big caps at 4700uf 35v
C3 100uf 50v
C4 100uf 50v
C13 10uf 50v
C14 10uf 50v
C15 10uf 50v
C16 2,2uf 50v
C17 10uf 50v
C18 2,2uf 50v
C19 2,2uf 50v
C20 2,2uf 50v
C21 1uf 50v
C22 1uf 50v
C23 33uf 50v
C25 33uf 50v
And power board.do not have the positions in this list yet
Nvs 4000 power Part
3x 10v 6800uf
1x 16v 2200
1x 200v 820
1 x 25v 100uf
2 x 50v 0,47uf
2x 50v 10uf
1x 35v 22uf
1x 50v 1uf
1x 35v 47uf
the caplist is useless without diameters.
anyway, moving on - what's wrong with the mosfet?
if it's shorted to the gate pin then the driver circuit will also be damaged.
Looks like the is some more Damage after the mosfet because of shortage. it does not turn on full after replacement.
ist like on /off Swinging.
where or what is the Driver circuit. can you please tell or Show me.
thanks
for the Diameters. normally you don't find the same measures for all anyway. and there is enough space for most.but i could measure some stuff if anyone wants.
driver circuit is the parts connected to the gate pin.
download a datasheet to see which pin that is.
i will try to see where it goes. no idea where to get this datasheet though.
not much information about this psu
