ShinGouki94
Anyone else have trouble selecting games on the CPS3 menu. Pressing up and down seems to skip games quickly. Stick is fine in game though.
USA can be a bit tricky to select, but I usually jump down the list past it, then hit back up to try and get it.Is there a work around?
Yea, its called keep trying to tap the joystick around until you finally land on the item you want to select.Is there a work around?
Yes it's a normal issue. It works perfect on MAME but for some reason didn't test properly before release. When I release the next version it'll be fixed...Yea, its called keep trying to tap the joystick around until you finally land on the item you want to select.Is there a work around?
When I first tried my superbios I thought maybe there was something flaky with my CPS3, but then when the CPS3 test menus worked normal, I realized it must be a button sampling issue in the code or something.Yes it's a normal issue. It works perfect on MAME but for some reason didn't test properly before release. When I release the next version it'll be fixed...
