Suzuki_Bison
NY
So the monitor inside my astro is omitting a high-frequency tone. I was working with an arcade-tech friend of mine who thinks it could need a re-cap, or possibly could be a voltage issue, but we're not 100% sure. The ringing seems to change pitch when the flyback is touched or nudged (we were sure to test this safely).
Anyone else ever experienced this before?
If it has screws that mount the flyback to the chassis, try tightening them down a bit. The flyback vibrating can make a god-awful whining sound.
Ill definitely look into this!! Also, I have to correct myself that the monitor actually is an MS8-29, not the MS9.
normally a noisy coil down the side of the flyback
i heard this can be the issue as well, would a cap-kit solve this (planning on recap anyway) or is the coil something totally separate I need to purchase?
i desolder the coil and check if its fully intact then resolder and use a hot glue gun to hold in place using the heatshield as the glue anchor point to the coil- it helps prevent vibration and should quieten the coil down significantly
