Multiple MVS 4 Slot Repair Log - In Progress
xodaraP
Legendary
Gold Coast, Australia
Hi everyone,
I was asked to repair a box full of 4 slot MVS boards by an operator friend.
I pulled the first one out today and decided to start a log as I go and hopefully get at least a couple of these up and running (some are believed to be beyond repair but will be good for parts supply!)
Board 1 Fault: Video RAM Error - In progress
Board 2 Fault: Video RAM Error - Repaired!
Board 3 Fault: Fast Video Ram (8000 region) error - Repaired!
Board 4 Fault: Crosshatch of death - Repaired!
Board 5 Fault: Click of death - Repaired!
Board 6 Fault: Major corrosion. Both top and bottom boards beyond repair
Board 7 Fault: Major corrosion. Both top and bottom boards beyond repair.
Standard upgrades/cleaning for all boards:
- Batteries removed and coin cell holder installed
- Battery area scrubbed clean to remove any previous acid leakage
- Rechargeable CR2032 installed
- Board cleaned using Simple Green
- Flux residue cleaned using isopropyl alcohol
- Cart slots cleaned with isopropyl alcohol
Board 1
Replaced both 62256 surface mount video RAM (twice, the first replacement set was also faulty!)
Additional Fault: Video RAM Error at $8000
Fix: Replaced both fast video RAM (Sony CXK5814)
Additional Fault: Crosshatch of death
Current Status: Repaired 3 traces that all failed continuity test. Board is currently still not booting on any slot.
Tested top board. Slots 2 and 4 boot with graphics issues, no boot slot 1 and 3. No sound on any slot.
Board 4
Repaired trace destroyed by battery damage
Video RAM error reported
Replaced 62256 video RAM
Z80 error reported
Replaced Z80
Board still not booting any games
Tried previously tested/known working top board - all 4 slots working
Repair complete!
Board 5
Clicks regularly on startup, does not proceed through boot process
In progress. Board was very dirty and has been properly cleaned before proceeding with repairs.
Click of death
Replaced work RAM - click of death on different colour screen
Replaced BIOS with UniBIOS and boots to crosshatch
Burned factory BIOS to replace dead mask ROM - now reports fast video RAM error
Socketed and replaced fast video RAM
Fast video RAM error expecting AAAA received AAEA
Metered out working board and found bad trace on pin 11 to LSPC custom
Repaired trace on underside of board
Board now booting on all 4 slots, repair complete!
