rewrite
Multi Boyz Litigator
Immortal
Multi Boyz
SoCal
So it doesn't look like Digikey has anything similar at all. It's a great big 20mm dia cap that's 40mm tall, and the closest thing to it is about 1/4 the size :/.
What are you all ordering for this part when doing cap kits on these?
So some research points to this being a no longer manufactured part from Chemi-con from their KXB series. I don't know that anyone makes any that are this tall with that capacitance anymore, I couldn't find any in any of the datasheets from rubycon or nichicon. Most of the 6.8uf (regardless of voltage) I could find were in the neighborhood of 10x20 +/- a few millimeters. Would something that has the same leg spacing work out for you as long as it has the correct specs?
If it has the correct specs that would be fine. Usually though when you go /that/ much smaller, other specs don't match up any longer. At least ESR doesn't.
Also thank you for doing some research on it!
