300wins
San Jose, California
Today I turned on my New Net City and it didn't turn on. Took the chassis out and found that the inductor at L411 broke somehow.
This inductor is coming from the Toshiba perfect flat chassis with PD-1843 stamped on the chassis. I don't know the value, so I don't know where to get a replacement.
If someone with the PD-1843 can measure the value needed, I would appreciate it. Thanks in advance.
look at the base where the wire is wrapped around the pins.
often when a coil or transformer just fails the wire has broken at one of the pins and you can solder it.
i suspect it's because the machine used to strip/wrap the wire causes a weakpoint.
The point where it broke was such a pain to get to, that the coil had to be unwound. Then the point where it broke was soldered back, then rewound. Unfortunately, that didn't help.
well if you counted the turns you could make a new one.
just use wire the same diameter
