Chamma to Jamma pinout using a switch
    • Chamma to Jamma pinout using a switch
      Is it possible to use a Switch to change between Chamma and Jamma pinouts?
      Let me known if I wrong but if I use a 3PDT switch like this:
      I would connect the db15 pins corresponding to the tree kick buttons on positions 2, 5, and 8.
      1, 4 and 7 i would solder the jamma pins corresponding to the chamma kicks (jamma 25,26 and 27)
      And 3, 6 and 9 to the kick harness connector on the supergun.
      Would that work?
    • You're sending ground (jamma pin 27) to either the DB15 or kick connector, so you're not really addressing the issue. You'll also need to handle player 2 inputs as well.
      You can tie the DB15 and kick inputs together and use a switch to enable or disable the DB15 and kick connector from the jamma edge.
      So with the switch you show:
      Jamma pins 25 26 27 to switch 2 5 8
      Switch 1 4 7 to the DB15 and kick connector
      Switch 3 6 floating and 9 to ground.
    • Beg @RGB to produce another run of the fantastic RECO device.
      It offers button remapping, voltmeter, negatron support just like the HAS...
      But most important for your usage accepts Chamma (buttons 4/5 on the edge, 6 externally) and consolidates them into CPS2 style kicks with normal JAMMA.
      You can see mine here...
      Yea the Vewlix JAMMA kit is actually wired for Chamma. *facepalm*
      Darksoft: CPS3, CPS2, F3, MVS
      RGB: RECO v2, HAS v3
      invzim: Jammafier v1.6b
      I see, I would need a switch for each player. Any other way of doing this? Would a Dip switch work too?
      That seems awesome.
      I don't use Chamma compatible boards myself but someone asked me if i could build a supergun that supports the Pandora Box, so I'm seeking help here.
