@syntax_X i'm curious, why do you think that replacing the bus chips on your multi will solve your problem? did you have the exact same issue as whoever BEN FONG is? personally I wouldn't touch the multi beyond the required soldering. removing/replacing bus chips is probably going to put you in a tough spot if you wanted to get it replaced. This thread has been stale for 2 months, just bump @Darksoft, and see if he thinks that solution is viable for your issue, first.
I can't speak for him either but your 1st post did start with "had this for about a year" and I know the warranty isn't forever for a send-it-back kind of thing. Might be why it wasn't offered.
