CPS2 4 Player Harness
xodaraP
Legendary
Gold Coast, Australia
I was asked by @Reading-comics to make an adapter for CPS2 3/4 player with DB15 connectors to allow Neo CD pads to be used for players 3 and 4
There is an ebay seller who offers these, but there is no voltage connection to the 3P/4P controllers and the Neo CD pads and a lot of other controllers require 5V for the controller to function. I offered to make one so it was local and also corrected this issue.
The kick connector on CPS2 has +12 for player 3 and 4 coin mechanisms, but no +5 because it isn't required for use in a 4P cab. To solve this problem, I installed a 7805 voltage regulator inside the DB15 housing for each player.
It took quite a while to put together but I was happy with the end result so I thought I'd post up pictures :)
Here is the test fit so I could confirm the 7805 would fit alongside the DB15 connector. It's a very tight fit, but it works.
And here it is with all 3 wires connected. All wire connections have been protected against shorts with heatshrink on the regulator and the DB15
DB15 connections soldered
And here is the finished cable - please ignore my messy workbench, creating this thing made a LOT of mess.
Hi
Where can i put the voltage regulator,in which pin
Thanks
I'm not sure I understand what you mean. Pin 5/6 outputs the 12V from the CPS2 motherboard connector end.
I also connected the ground for the regulator back to the motherboard to pins 1 and 2
The 5v in this case goes to pin 8 which is the Neo standard.
