Looks like a variation on this, which is easy to source: KI2 DOM (Killer Instinct 2 Disc on Module)@Kundi That looks sweet! And I've never seen a KI pcb without a mounted SSD. Who did those chips replacement?
I have ArcadeCup's SSD module on my KI which I really like. Just had never seen that before.Looks like a variation on this, which is easy to source: KI2 DOM (Killer Instinct 2 Disc on Module)@Kundi That looks sweet! And I've never seen a KI pcb without a mounted SSD. Who did those chips replacement?
They are a bit on the expensive side, but its a fair cost though if you are doing it as a business. I would estimate roughly $30 for the 2 pieces of plexi, add the hardware, etc... Then there is the cost of electric to engrave, run laser, wear & tear, plus labor etc.. so in the end its a fair .Those Highflow cases are spendy, but I've heard a lot of good feedback on them so far. Looking forward to your take on them @jassin000!
Oh these aren't my first by any stretch, I keep coming back for more because they ARE so good!but I've heard a lot of good feedback on them so far. Looking forward to your take on them @jassin000!
What I want is some cases for boards Highflow hasn't got...They are a bit on the expensive side, but its a fair cost though if you are doing it as a business.
Hey @Telpherion, thanks so much for sharing these for FREE. Postage for these cases have stopped me from getting them from sellers in the past, but there’s a lot of plastic places everywhere who do custom jobs, usually with offcuts which make it cheaper (I believe an etched case will only cost me $35 USD + $5-10 in washers and offsets).Hi all! I'm Emiliano from Argentina. I've been collecting boards and learning electronic related stuff from 1 year and I'm happy to be part of the Forum, thanks!
I started doing custom cases to protect, store and display my games. I use acrylic and any laser cut store to doing them. I've created an open repository on GitHub to share all the design with you. On the repository you will find all the instructions and files needed.
You will find very interesting that the case for Killer Instinct board has a cooler to solve the heat problem on the CPU that leads to burn this board usually On my tests, the CPU runs almost at environment temperature with the case, will never turn on a Killer Instinct without a cooler over the CPU, the regular CPU temperature really scared me.
Other interesting fact is that you can tell the laser cut store that they engrave the Logos on the acrylic, this looks amazing!
I will keep updating the repository with new designs all the time, so feel free to star the repo and receive a notification when I upload new boards. I've already received some pictures of people using them, so I'm very happy to share this and that it could be useful for others.
The repo is: https://github.com/emilianoarlettaz/arcade-pcb-case
A picture from one design:
For reference sake, the CPS-3 bottom are 25mm, the top are 40mm to allow clearance for the SIMMS.Definitely getting one of these made up for KI
For fan clearance, what size standoffs did you use?
Have to check if I have a spare Bubble Bobble, I donated mine to Hatsune Mike for his contributions to the hobby and he in turn sent me a splitfire as a thank youWhat I want is some cases for boards Highflow hasn't got...
Bubble Bobble (RomStar)
Super Buster Bros. (Capcom/Mitchel)
BB needs a proper case, maybe one that incorporates the jamma adapter. @XianXi makes the best one, need to get one of those.oh need bubble bobble :3
thats a shame i dont own a real romstar
indeed , i have a few stuff from JNx and they're spot on :3BB needs a proper case, maybe one that incorporates the jamma adapter. @XianXi makes the best one, need to get one of those.
Made a slight edit to my post above.I have a superpang somewhere, but same deal, if get me the measurements/logos, Ill cut you a case at cost of the acrylic.
M92 (Right now R-Type Leo, but soon hopefully multi!)
Oh man, forgot about the M92, i have so many of those boards lol, i should make a case. Any ideas!M92 (Right now R-Type Leo, but soon hopefully multi!)
I'm working on M92 cases right now! Already have a prototype done for In The Hunt.What I want is some cases for boards Highflow hasn't got...They are a bit on the expensive side, but its a fair cost though if you are doing it as a business.
- Bubble Bobble (RomStar)
- Super Buster Bros. (Capcom/Mitchel)
- M92 (Right now R-Type Leo, but soon hopefully multi!)
