Finished my First Consolized Naomi
    • Finished my First Consolized Naomi
      So got a little free time over the weekend, and finally finished this thing off. Everything went well after discovering the paint inside was conductive. Already got a second one started. Still on the fence about what I want to do with the sound. I still have plenty of room left over for an amp inside, but not sure what route I will take.
      Tommy
      Images
      Tommy
      Nice work.
      Now, it's time to graduate to the multi.
      This Naomi should take you for a ride...
      Videogame Historian
      Bench : M92 Conversion|Z-back Naomi Multi Cabinet
      WANT : EPROMs, Taito F2 Rom Boards
      [astrocity] InstaGram [neogeo] Arcade Projects Photoblog [saturn] VAPS List [nes-101] Tuesday Arcade Twitch Stream!
      Tommy
      The stereo connectors on the side are line level out, you can plug them into a TV or a separate amplifier/speaker set.
      Or are you trying to power speakers directly from the Naomi?
      Anyway, great job on the consolization.
    • Appreciate the comments everyone.
      To answer a few questions,
      I will open it up and take some inside shots for you all here soon.
      The power supply I used was a Pico 160 watt
      The controllers I did with half of a Dreamcast port, from a DC that wouldn't read games at all anymore. Had it setting around the last year or so. I split those in half, then dremeled the board down to remove any connections except the 5 needed ones. Then I used the 3 holes that were still there on the board to mount with those bolts you see in the picture. I didn't want it going anywhere in case someone got salty and ripped the controller from the port...it happens I mean its marvel.
      Thirdly, as for the sound. I know that the audio out is on the front, but I am not sure if I want to put a built in amp, or just use an external. Some of the smaller, not to badly priced speakers sound really good now, and they would def fit inside there. But I don't know yet. The only downside I see to that would be slightly more heat, and the possibility of loose connections from any small vibrations going on. The only reason I considered putting speakers and an amp in there is because none of the crt monitors I use have speakers on them. The monitor in the picture is just a smaller test monitor I keep in my shop. And it would be one less thing to lug around.
      Anyways I already have a second Naomi ready to start another mod for, not sure what I want to do with it yet. I could have had a multi Naomi 2 setup, but I opted for this one instead. Used to have an mvc2 Naomi setup years ago in a Neo candy 29 and sold it back in 2005. Been kicking myself ever since. This time I was going to build a head to head setup from scratch in a sit down candy style cab only with crt monitors, but the more I thought about it. This setup just made more sense. Everyone that plays marvel basically uses a different stick, some like Sanwa, some Happ style so this was the best option. Plus now I can take it with me if I want to travel to their houses to play. When I figure out what I'm doing with the next one I will be sure to post updates.
      Tommy
