Blue_Fox
Northern California
In Preparation to preorder a life size one from @hursit I began to make this tiny Beauty. The body was SLA printed and I Used a Raspberry Pi and a 2.2 in LCD for the electronics.
After Everything was sanded and painted and I began to fit in the electronics.
The Front glass was also SLA printed and then sanded and covered with clearcoat before I placed on the window tinting film.
Here is the finished version. There are a couple of things I will change for any future iterations but I am happy with the results for now.
OK, what's the story on the analog stick made out of a Sanwa JLF?
The story is I was attempting to build a fight stick for Smash and needed an analogue joystick.
I was lucky enough to get an LS-64 Analog joystick but the pot values where wrong and the sensitivity was horrible but it was supper smooth.
As a result I attempted to make my own. I would want to build a hall effect joystick but I am not an electrical engineer and I thought that may be a bit time consuming. Therefore, I took the engineering knowledge I had and fused a JLF with an Adafruit analogue stick. I am happy with the results to the point where I have made 2 for 2 different fightsticks.
I will do a separate post about everything in the future but for those reading this and want context here are some pictures
Left Prototype version before I added the JLF. Right JLF version way smoother but not perfect.
First Smash Fightstick
Second version
