Hy
i am Looking for good guides on how to make picture Adjustments on these New Astro cab Monitors (ms9 29).
emphatic.se/?p=710
wiki.arcadeotaku.com/w/How_to_…or_Colours_and_Brightness
These guides i used. but they do not follow the same way basically. tried both but still do have for example the sharpness differences at the outer parts of the screen.
my red will not go as high enough as the green and blue without turning the black into red/black.
Also when i turn down the cutof and gains to Zero the General Color tone of the screen stays blue black.which is no good Point to start off i guess.
are there any other guides you People know or personal experiences with which values to start the process. for example cutoffs at mid Level and gains on Zero bright on Zero Sub contrast on mid and then do sreen Level to where the test grid just vanishes.from there then adding cutoff Colors and gain Colors and so on.
And last Question. will it help to improve the sharpnes over the whole screen if i recap the Chassis.or does this have no effect at all?
thanks
emphatic.se/?p=710
thanks
