WOW, nice work.added the missing A18-M68k address line to the roms and to the 68k cpu, and changed the pin 11 input of ic45 pal input to A19-M68k
Just a couple of wire mods, no rom patches.So in addition to adding the above connections did you have to cut any traces? And did you have to modify the ROMs at all?
Thanks, i only had to cut 1 trace which was the original signal to the pin11 of the ic45 pal ic, so i could attach the higher address line to it for the new 27c020 game roms.WOW, nice work.
indeed. though Ninja Kids isn't that rare or valuable of a game. If you're interested I have an original Ninja Kids ROM board I can do some testing on though.Ninja kids is the only other game that may run on this particular board. (TE7750 chip)
Not looked at it. The config for ninja kids has 1 less graphics chip compared to football champ h/w.
Yeah i think part of the issue was the confusing file names etc. Much studying of original board pics to sort them out.Well done! Thanks for finishing this one, it was sitting around for a long time.
Seems that fresh eyes on this one was all that was needed!
I re-burned all the GFX roms and took the extra 74 off and patched a couple of traces that had been cut....
Can confirm it's working!!!
Only note with the roms is that rom 8 = rom 9 and rom 9 = rom 10.
rom 10 in mame archive is the sample rom (rom 57 on the F.C board)
I have 2x Thunder Fox. Is there something I could convert one of them to?Ninja kids is the only other game that may run on this particular board. (TE7750 chip)
Liquid Kids looks like the only other board with matching taito Customs.I threw this chart together a while back when I was trying to figure out what potential conversion candidates were...
Nice work mateI have some more progress to report. I found that one of my original game roms i burned for the conversion was the wrong one meaning my rom0 upper data bits were wrong. Once i had this rectified and changed i got this with dip switch 3 enabled. Phew!
I burned a set of the large 27c400 and 27c800 roms to swap into by board and now i have a working game Took awhile to get a programmer that would burn the higher sized 16 bit roms needed, but glad i did.
Video of the intro running here on my instagram feed : https://www.instagram.com/p/B83ZtpvnXrB
So if anyone needs a set of roms for the conversion please let me know. I'm still interested to know more about ic72 and what its for, because it doesnt seem to be needed, or the version of board i have is ok without it.
Off to play some dead connection
YesNice work mate
Does it still need the wire patch on the backside of the PCB?
