Please check the pictures. I have marked it with Red lines. I need H,W and corner to corner measurements.What do you need?
thank you very much
it is good news.I actually got my tube two days ago! Haven't had time to throw it in the cab yet, but it's in the house. Progress!
thanksHursit is a man on a mission!
I'll test the tube in the stock cab first, I think that'd be beneficial?it is good news.I can ship to you if you can test itI actually got my tube two days ago! Haven't had time to throw it in the cab yet, but it's in the house. Progress!
Yes thats greatI'll test the tube in the stock cab first, I think that'd be beneficial?it is good news.I can ship to you if you can test itI actually got my tube two days ago! Haven't had time to throw it in the cab yet, but it's in the house. Progress!
Works for me though. I think you already have my address?
Sorry Bro but i have only prototype for nowI have 3 K7000's (2 Wells Gardner & 1 Zenith K7000A). If you need me to test too, let me know. If you can send more than one to rewrite, he might be able to ship to me one. Cheaper that way.
Thanks for the infoAll right.
Update time:
A 19" WG tube *will* fit both vertically and horizontally and be visible. Tube will have to be mounted with no frame attached. Center hole to center hole measurements: hori is 430mm. Vert is 337mm.
The mounting points for the monitor in the cab will have to be changed from stock, but that shouldn't be a big deal. 8 mounting bolts instead of 4 since the tube won't have a square frame on it.
I don't have a neck card, but it /looks/ like it'll be fine with one on there depth-wise. Maybe someone can lend me one? It'd be real cheap to ship.
The prototype does not fit in the original bezel holder. It's too wide in hori, and just doesn't fit at all tate. It's not the same size as the original. It should be 440mm square. For reference the one I was sent is: 452*425.
The prototype's cut-out is the perfect size. It needs to be centered though.
