I've had no issues with any of the G-Net PCB's I've bought - the most desirable one has the piggyback PCB with long capacitors on (high score save pcb). There's also a network card add-on.
Test it works properly first and make sure you have +5V set correctly, they're a bit fragile voltage wise and will die quite quickly if +5V is too high and will sit in a reboot loop if too low.
If you are prepared to wait for one they can still be picked up for $60-70.
simple job to flash too - insert chip with modbios 2011, fit jumper on pins, power on and wait for flash to finish, power off, remove chip & jumper, power on and you're sorted.
I think there's a backup copy of the bios onboard as I'm sure I've had one revert back to stock after shorting out something on the bottom of the pcb.
