buffi
Sweden
I'm getting some conflicting info on the jumpers on the CPS2 board I'm planning to convert into a multi.
In the PDF with the instructions for the multi, it says:
"SECOND STEP
There is no need to modify the jumper configuration. Just leave them as they are."
But in the video linked from the original post it specifies this jumper configuration:
... which is different from JP8-JP13 on my board: (9, 10 and 12 closed)
Which one is it? Should I rejumper this according to that old video or use the PDF instructions and leave them as is?
Edit: I'm using a F PAL which I plan to connect (pin7) to the J17 pin if that makes a difference
Video is old info. Jumpers should not need to be changed if the original game worked ok.
