it is in MAME romset for many yearsraw flash image was what i was talking about
I'd say - there was no interested enough person, who have skills to hack DIMM firmware, and wants CD support added
there only hacked 4.01 with CF vendor check disabled, which people call "4.02"
Always fun connecting dots and trails of bits around here... (forgive the awful translation):Before net booting and CF boooting, there was CD-R booting. You need to patch the DIMM firmware to disable media-check (GD-R vs CD-R) and a few other things, I have tried this myself and it works, somewhat. Unfortunately, at least my setup failed after 1 hour of game-play - probably another mediacheck somehwere that triggered a reset.
I'm not aware of anyone managing to patch the firmware properly to avoid the reboot after an hour+.
true, but there was unsolved side effects like reset after some time, which makes in ususable at practice, so that hack was abandoned in prior of CF or Net boot methods.this hack (the essence - a patch of 2 bytes in the firmware
About the only thing they are good for nowI mean, CD-Rs suck anyway.
So basically it needs further patching, right? Any clue about what could trigger it? Another GDRom check? Timing issues?true, but there was unsolved side effects like reset after some time, which makes in ususable at practice, so that hack was abandoned in prior of CF or Net boot methods.this hack (the essence - a patch of 2 bytes in the firmware
From what I know there was an additional media check after 1 hour.So basically it needs further patching, right? Any clue about what could trigger it? Another GDRom check? Timing issues?true, but there was unsolved side effects like reset after some time, which makes in ususable at practice, so that hack was abandoned in prior of CF or Net boot methods.this hack (the essence - a patch of 2 bytes in the firmware
I'm a little surprised no one has tried to adapt the GDEmu device to Naomi.I agree that CF is better, but the good thing of using CDR is that you can also have that option and games take in most cases less than 256Mb. Also GDRoms are hard and expensive to find, not to mention that it's not available for everyone to burn them.
To be fair... this is a subjective opinion. Considering most Naomi1 or Naomi2 games hover around 240M in size, topping out at 459M for Virtua Striker. Same for Chihiro games in many cases. Wangan comes in at 485M.From what I know there was an additional media check after 1 hour.
Anyway this track is dead, no point in using a CD-R which has less capacity than a GD-ROM when we have the CF solution.
from a preservation standpoint it is nice to have many options / choices.I agree that CF is better, but the good thing of using CDR is that you can also have that option and games take in most cases less than 256Mb. Also GDRoms are hard and expensive to find, not to mention that it's not available for everyone to burn them.
IMO CF is dead storage media, just like CD-R.Likewise the CF solutions are quite the investment up front
*Gasp* Is this the beginning of the official Naomi "multi" announcement!!!!!!!!1but the best would a device with RAM that replaces the DIMM as well.
You would not need to clone anything the GD-ROM uses the same connector.I'm a little surprised no one has tried to adapt the GDEmu device to Naomi.If the Chinese can clone it, I'm sure you could hackup the original/official firmware to make it work.
*update* Oh I guess it would need some type of adapter and voltage regulator board as well.
right, there is probably some kind of scheduled checks, iirc there is PIC check routine, and disk presence check routine, but I have no good ideas why it may not work for CD-R.That reset was patched in the CF version. I guess it can also be easily patched in the GDRom version, if the code that does the check is similar or jumps to similar positions for reset, etc.
to be fair... @rtw is examined GD images from Naomi/Chihiro/Triforce and know how many data written on.To be fair... this is a subjective opinion. Considering most Naomi1 or Naomi2 games hover around 240M in size, topping out at 459M for Virtua Striker. Same for Chihiro games in many cases. Wangan comes in at 485M.
