The Definitive Guide to the System 16 Multi Kit
    • The Definitive Guide to the System 16 Multi Kit
      Hi everyone,
      Now that the S16 multi kit is due to start shipping soon, I have asked the team to share some details on the initial setup!
      Congratulations on your purchase of the System 16 Multi! Now that you have your kit, or even if you haven't yet received it, where do you go from here?
      Before we begin:
      - This guide assumes that the S16 motherboard you are using is currently fully working with non encrypted CPUs
      - No information on modifications to your motherboard aside from installation of the reset wire is or will be included
      - Windows OS will be required to run the ROM conversion tool
      You will need:
      - S16 Multi ROM board
      - S16 Motherboard with non encrypted 68000 and Z80 installed
      - EPROM Programmer compatible with 27C322 and 27C080/801
      - Temperature controlled soldering iron (for reset wire)
      - 14x 27C322 and 1x 27C801 EPROMs (if you did not purchase these with your kit)
      Optional:
      - S16 Multi Rotary Selector
      Programming EPROMs:
      ROMs are not supplied and will need to be burnt to EPROMs and installed onto the kit. These are the MAME files that will need to be located, for almost all games there is a decrypted set and a parent set. The decrypted sets include the main program code only and will not function without the parent set for each game.
      Any decrypted set for the game can be used, but the sets below have been tested:
      Decrypted:
      Aurail - aurail1d
      Bayroute - bayrouted
      Cotton - cottond
      Dynamite Dux - dduxd
      E-Swat - eswatj1d
      Golden Axe - goldnaxe3d
      M.V.P - mvpjd
      Wrestle War - wrestwa2d
      Excite League - exctleagd
      Passing Shot - passshtd
      Super League - suprleagd
      Sukeban Jansi Ryoku - sjryukod
      Ace Attacker - aceattacd
      Shinobi - shinobi2d
      Sonic Boom - sonicbomd
      Wonder Boy 3 - wb32d
      Alien Syndrome - aliensyn
      Bullet - bulletd
      Dunk Shot - dunkshotd
      S.D.I - sdibl
      Time Scanner - timescan
      Flash Point - fpointd
      Tough Turf - tturfu_no_mcu
      Action Fighter - afightere
      Riot City - riotcity
      Altered Beast - altbeast2
      Heavyweight Champ - hwchamp
      Toryumon - toryumon
      Ryu Kyu - ryukyud
      Tetris - tetris2d
      Parent:
      Aurail - aurail
      Bay Route - bayroute
      Dynamite Dux - ddux
      E-Swat - eswatj1
      M.V.P - mvpj
      Wrestle War - wrestwar
      Shinobi - shinobi2
      Wonder Boy 3 - wb32
      Bullet - bullet
      Tough Turf - tturfu
      Ryu Kyu - ryukyu
      Tetris - tetris2
      Other:
      Fantasy Zone Time Attack - fantzone_s16b
      Bloxeed - bloxeed_s16b
      All ROM files will need to be extracted to a directory with the same name. When extracting each ZIP file (for example with 7zip) click the
      <Information and photo to be added here>
      Once all zip files have been extracted you will now have each game in a folder with the same name as the ZIP file, and the ZIP files can now be deleted or removed.
      <Photo to be added here>
      Copy the ROM conversion tool to this folder and run the tool.
      You will now have 15 files which should be the following file sizes:
      01-13 and 15 - 4mb each
      14 - 1mb
      If the final files you have are not the correct size, the tool has not been able to operate correctly. This usually means that incorrect or missing ROM files have been supplied.
      Once you have the correct files available, burn these to EPROMs
      01-13 and 15 - 27C322
      14 - 27C080/801
      The EPROMs can now be installed into the correct positions on the multi kit ROM board.
      Reset wire installation:
      Once the EPROMs are installed into the board, the reset wire can be installed, this needs to be connected to the reset wire position on the ROM board
      And soldered to Pin 8 of the 3771 Power Management IC at position A1 (bottom left of the board)
      Here are some examples of other locations the reset line is connected to if you prefer to use one of these for better wire routing or another reason:
      - Pin 4 of LS74 @ C1
      - Pin 9 of 8751 @ B2
      - Pin 1 of LS273 @ C17
      - Pin 26 of Z80B @ D15
      - Pin A12 of CN5
      Optional: Rotary Selector Installation
      <Information to be supplied here once available>
    • Now that your kit is installed, you will want to play some games!
      There are 5 DIP switches and these will need to be set in a specific combination for each game.
      The numbers below are DIP switch 1-5
      0 - Off
      1 - On
      DIP Switch Settings:
      Excite League - 00000
      Passing Shot - 10000
      Super League - 01000
      Sukeban Jansi Ryuko - 11000
      Ace Attacker - 00100
      Shinobi - 10100
      Sonic Boom - 01100
      Wonderboy III - 11100
      Alien Syndrome - 00010
      Bullet - 10010
      Dunk Shot - 01010
      SDI - 11010
      Time Scanner - 00110
      Flash Point - 10110
      Tough Turf - 01110
      Action Fighter - 11110
      Aurail - 00001
      Bay Route - 10001
      Cotton - 01001
      Dynamite Dux - 11001
      E-Swat - 00101
      Golden Axe - 10101
      M.V.P - 01101
      Wrestle War - 11101
      Riot City - 00011
      Altered Beast - 10011
      Heavyweight Champ - 01011
      Toryumon - 11011
      Fantasy Zone Time Attack - 00111
      Ryu Kyu - 10111
      Tetris - 01111
      Bloxeed - 11111
      The post was edited 1 time, last by xodaraP ().
    • Thanks for the guide. @xodaraP
      also, i began looking up the DIP settings for the games, i'll provide a cheat sheet like the one i did for the M72 Multi
      I'll be posting it here in theis post once it's finished.
      Darksoft: CPS2, MVS, Taito F3, Sega ST-V
      Apocalypse: Irem M72
      RGB: HAS 3.1
      Frank_fjs: Sentinel Supergun, 4xMD2NEO (2 old, 2 new), 2xSNES2NEO, Jamma Extender w. Kick extension
      XianXi: Spitfire
      Cab: Sega Blast City (2930)
      VAPS
      Words to live by
    • xodaraP wrote:
      I actually just asked him about that both so I can add it to the guide and get one myself :)
      Yes sir . And if a new batch will not be builded , @oneleaf86 already realesed the files for everyone if anyone wants to makes on their own . All great from now on ^^
      Multi's: CPS2 / Taito F3 / Irem M72
      Superguns : HAS v3.1
      Scart switch : Gscartsw V5.2
      JNX: Spitfire
      NAC: Splitfire
      My Arcade Stuff
    • Sp33dFr34k wrote:
      Looks like a solid guide bud, nice work. Now to get one of those rotary selectors... :)
      The guide will be updated with more information as required like the CPS2 guides - and photos once I have the kit. I'll update it soon with the rotary selector details
      @oneleaf86 has been kind enough to make the files and parts list freely available as @AlxUnderBase linked above. So you can make your own now :)
