Reviving suicided Gaelco PCBs : The Right Way
    • caius wrote:
      Non-volatile RAMs?I don't know, I never tried.It could work, I can do some test.
      I've read the documentation of the DSP and in case of battery power loss (it's an input pin) it resets the keys. That said if you tie it to the +5V rail on the PCB (maybe through a diode or resistor to lower level since there's might also be a voltage check) it might do the trick.
      Looking for:
      - Sega Super Scaler hardware (Out Run, Model X, Model Y), not working (even with faulty PCM chip)
    • caius wrote:
      Someone asked me in the past to explain how to properly desuicide other Gaelco games than the usual World Rally so here we go :
      caiusarcade.blogspot.com/2020/…aelco-pcbs-right-way.html
      Credits to Peter Wilhelmsen and Morten Shearman Kirkegaard (R.I.P) for their research and help.
      thank you! That's the spirit.
    • Apologies in advance, I'll probably be asking a bunch of dumb newbie questions in the coming few weeks, since this thing is completely new to me, and the documentation here is kind of sparse/spread out.
      I'll be documenting my own progress, so maybe the result will help others in the future.
      One thing that's confusing me is @Apocalypse 's post on neo-geo.com stating that the VCC pin isn't used when connecting to the TTL(?) interface on the board. Am I to assume that the entire PCB needs to be powered via the JAMMA connector for this to work?
      And in this case, does it matter what the game is doing? Just do this while attract mode is running?
      And pin 4 (/PROG) can just be connected to one of JAMMA ground pins, then?
      I replaced the battery yesterday and I'm still waiting for my USB thing to arrive in the mail. The battery still measured 3 volts, so I hope I'm not doing something futile here.
    • @Sumez yes you must power the PCB (preferably through JAMMA).
      The prog pin can simply bridged to the nearby gnd pin.
      Looking for:
    • Can. If you ground it from the JAMMA edge it will also work.
      To connect the required signals I simply used male strip pins with wires soldered to them.
      Looking for:
    • I think I've done everything as suggested, but I'm still getting the "coprocessor not ready" after resetting the board.
      My best guess is that I didn't upload the file correctly.
      The whole converting the data into intel hex format is a bit confusing to me. Even finding a utility that was able to do that correctly was a hassle.
      I downloaded the wrdallas.hex file from @Apocalypse 's neo-geo.com thread, and comparing to the one I got from converting "aligator_ds5002fp_sram.bin" from mame, mine was one line longer, despite both sources being exactly 32KB.
      Here are the first few lines from my file:
      Source Code
      1. :020000040000FA
      2. :20000000020040020040FFFFFFFFFF020040FFFFFFFFFF020040FFFFFFFFFF32FFFFFFFFB9
      3. :20002000FFFFFF32FFFFFFFFFFFFFF02042EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76
      4. :2000400075814075C67875D80075C180E5874408F58790F106E4F090FF7CE0A3F4F5F0E0DE
      5. :20006000A3F4F524E0A3B5F0EEE0B524EA12008F12008612039D90A00EE060FD14F012009B
      6. :20008000AF12038280F078247907E41203E922E4F5F0F8F97B007A30901000E029F95001B8
      So I assumed the first line was some kind of header that wasn't used in this context, and selected and copied the text from the second one forward, and after sending the L command in putty (L, then carriage return) I right clicked to paste (no visual feedback until the prompt comes back up after several minutes).
      I did the next stuff, and it seemed to do what it should, but I'm still not any closer to a functioning PCB.
      So what's the problem here? Should I have included the first line too? Did the file not convert correctly? (I used an utility called srec_cat.exe from a project called SRecord). Or did I do some other mistake?
      Here's what my resulting PuTTy window looked like:
    • The hex file is different for each game. Your aligator_ds5002fp_sram.bin is probably correct for your game. Just convert it to .hex then upload it.
      And yes keep that first line.
      Looking for:
      I don't doubt the .bin file, I doubt the .hex file, or maybe my method for transferring it.
      If I do include the first line I get an error message from the terminal (can't recall it, "ERR:BADCMD" or something like it), but if I paste the whole thing without that line, it acts like it works. Except the game is still suicided.
      If you had success with your .hex file, can you tell me the exact method you used to convert it?
    • Why does this have to be this hard?
      Of course that was the first thing I searched for. :P
      I found two "bin2hex" projects on the Internet, one was from 1999 and didn't work on anything much newer. I think it requires a 16-bit OS version, and doesn't run on Windows 10 at least.
      The other must have been something different entirely, because the stuff it outputs doesn't look like the intel hex format at all.
    • Binary is just data. It doesnt have any specific format. Hex file does. It has some offsets, checksums, etc. Moreover it depends on the manufacturer sometimes, but let's assume it uses Intel's HEX format. I just took my eprom programmer Software, opened the file as binary and then SAVE AS Hex. The result is attached.
      I don't know why you say that you are far from getting it working. Looks like you can connect and communicate with the Dallas, you are almost there!
      Maybe instead of loading the file, try pasting it into Putty.
      Let us know how it goes.
      Thanks.
      Files
    • Thanks a lot, Darksoft! Unfortunately, it looks like your file is completely identical to the one I had managed to create, minus the weird first line (see the Code bit that I pasted, lines 2-6 are the same as your lines 1-5).
      So it seems my issue might not be with the file I'm using, but maybe with the method I use to transfer it, or maybe there's another issue? I've replaced the battery, so I'm assuming it should be working.
      That's what I'm doing. Or at least that's what I think I'm doing:
      It's a little unclear what's happening because Putty itself doesn't give me any feedback (which makes sense, it relies on the hardware I'm connecting to to give me any feedback). After pasting the file, it just waits for several minutes, and then returns to the default ">", prompting me for input (see the image in my attachment above). No errors or anything.
      I don't think I ever said that I was far from getting it working. I'm just confused, because it looks like I'm doing stuff correctly, but the board still shows the same error when starting up.
    • @Sumez that happened to me before, there were some severed traces on the solder side under the battery area.
      Looking for:
