Voltage is 12.37V. I understand there is no wa to repair in some how the cart...Do you have a multimeter? Check it.
If it's ok, you can start to think about a new cart or SUPER BIOS.
OK, thanks for your help.No. As you have found the board boots without a cart in it to a garbage screen.
The main CPU for CPS3 is in the cart, if it's suicided it will not boot.
Nothing else matters, no jumpers, no motherboard settings, no motherboard battery, no missing or damaged CD.
If you do not get a game or error message on boot and your motherboard isn't completely dead, your cart has suicided.
Also, your voltage sounds very high. What is your 5v reading?
OK, thanks a lotYes, your voltages are high. You can mod your cart with a super bios.
Should I have to open the CPSIII case to put that SIMMs? I only would like to modify the cart game and nothing more... I guess I will not need the CD game in order to make run the modified cart.You will have to have complete SIMMs set (ready for 3rd strike) and burn a Darksorft CD. You can choose the version of super bios that fit for you.
So, I have to replace the SIMM inside the cart for the modified one, and nothing more... I don't want to open the CPSIII metal case...If you use a Superbios, the use of all SIMMs will be mandatory, you can't choose, but will be able to run all the 6 CPS3 games. You get the simm and install on socket, nothing more.
You can do it with any cart.
