EVLM
Im looking for a little guidance to find out exactly what boards can be turned into what games, I have aquired a cheap COTA green board and I am starting to investigate the process of conversion as I would like a SF2TX instead, is there any central resource which I can source the infomation from so I can research before the board arrives.
So, I should have a pal F board and I will need to convert it to pal B, is this possible, if so is their a guide on what pins go to where?
