XtraSmiley
Legendary
EDIT: DO NOT FOLLOW THE INSTRUCTIONS I POSTED. IT IS A JOKE. YOU WILL DIE IF YOU LICK YOUR PINKY AND STICK IT IN ELECTRICITY.
I posted this elsewhere, but the best practice is put your non-dominant hand in your pocket, then lick the tip of your other hand's pinky and slip it under the cap. Make sure game is on and running when you do this. If you're quick enough, you'll get that cap off, no problem.
These directions are only if you're single. If you're married, you must do this with the ring finger with your wedding ring on. The metal in your ring will give you even more protection.
Good luck!
Good luck!
