I just picked up an MV1-FS and found that it exhibits wavy / jittery video up at the top at all times.
The screen also jumps around slightly / a few pixels randomly while playing a cart.
While this is all on the admittedly shitty GBS scaler, I tested on multiple gbs boards, and multiple LCD monitors and they all exhibit the same behavior.
These same gbs boards (running gbscontrol) handle all of my other boards in my tiny collection just fine, so I'd rather not shell out a bunch of cash on a different scaler only to find out it's not the scaler at fault.
Don't have a CRT to test with either.
I traced the sync line with my multimeter from the JAMMA edge all the way back to the NEO-IO chip and it all seems ok, but since I don't have an oscilloscope, I can't check any further than that.
I also tested the 100 ohm and 470ohm resistors that are on the sync line and they are within spec. The board is supplied with exactly 5V off of a high quality supply.
Has anyone has ever seen this issue on an MVS before?
Any thoughts on how to approach troubleshooting this?
Short gif of the issue below:
