315-5242 colour encoder reproduction
    • 315-5242 colour encoder reproduction
      Hi all,
      I've been finally hit by the failure of that custom module. It's used on many Sega boards (X board, Y board, Systems C/C2/18/24/32) to increase palette.
      Since I don't have the tools to decap one I simply pulled a good one and studied it on the bench. It's rather simple (mainly latches and resistors to form a DAC). Only thing I'm not 100% sure of are resistors exact values. I set my PSU to +5.00V and measured voltage before and after the final amplification stage transistors then deducted resistors values for the DAC. One thing I've learned is you can get rid of the transistors by using appropriate resistors values. Sega used much higher values inside the on the module, I guess to limit power dissipation since they are film resistors.
      I've made a first repro on a piece of breadboard (a bit shitty since its a SDIP device) and will release gerbers and BOMs here as soon as they're ready scroll down for the gerbers.
      Cheers.
      [EDIT]
      Following the discoveries there:
      arcade-projects.com/forums/ind…-reproduction/#post231493
      I've found this repro is suitable only for System C/C2, X board, Y board and System 24.
      If you need one for S18 or S32 follow the link above to @caius repro thread.
      Or wait for me to reverse the greyscale effect (shouldn't be too difficult, RGB signals are converted to have equal weight resulting in grey being displayed, probably like Rin+Gin+Bin/3 = Rout, Gout, Bout).
      BOM:
      PartTypeRef.Comment
      J1Connector2*32p 0.7" strip pin
      U1, U2IC74LS273SOIC20, 300mil
      U3IC74LS74SOIC14, 150mil
      U4IC74LS125SOIC16, 150mil
      C1~4Capacitor100nF ceramic, 0805 footprint0805 footprint
      R1, R7, R13Resistor4K, 0805 footprintCan be substituted by a rounded value of 4,7K
      R2, R8, R14Resistor2K, 0805 footprintCan be substituted by a rounded value of 2,2K
      R3, R6, R9, R12, R16, R18~21Resistor1K, 0805 footprint
      R4, R10, R16Resistor500R, 0805 footprintCan be substituted by a rounded value of 470R
      R5, R11, R17Resistor250R, 0805 footprintCan be substituted by a rounded value of 220R
      Gerbers:
      gerbers_315_5242.zip
      Looking for:
      - Sega Mega-CD 1 power board
      The post was edited 7 times, last by Apocalypse ().
    • New
      I've reproduced the greyscale effect for S18 & S32. I will print few PCBs and if testing goes well I'll update the gerbers.
      Looking for:
