bravesirchris
UK,Devon
I'm having some trouble with a TC3, both guns work in the game but there is no recoil at all. I've swap over the gun i/o boards to see if that would do anything but no luck. any one have any ideas? ?(
Check the 24V power supply they have a bad habit of failing
If the psu does output the correct voltage, then it's a failed transistor on the gun I/O board and that depends on which type of guns they are; optical = v185; CCD SD = v221 MIU; CCD DX = JVS Rays. v185 I/O boards use a SLA4060 transistor to drive the gun recoil and is easy to replace. The other two I don't know of and haven't seen a component that drives the recoil fail on one of the two pcbs.
