Wells Gardner D9200
    • Wells Gardner D9200
      Hello guys I recently acquired a PGA tour arcade cabinet. it came with a trysinc Wells Gardner D9200.
      I have tried everything and nothing shows up on the screen. when you power the crt on and off you can here the turning on and off noise of the crt.
      when I plug a computer to it on the vga port, the computer react to it because the display on the second screen adjust to the crt resolution.
      when I send a 15khz signal to it on the rgb side I can here it react by a hiss kind of sound.
      in all thing I cannot get anything to display on the crt.
      it has a neck glow
      I have attached a video to give you an idea.
      imgur.com/a/YbQNpcr
      can anyone help, full disclosure I have bever work on a crt because and it it not my cup of tea.
      thank you for your help
      The post was edited 1 time, last by kazanova225 ().
    • Check for shorted parts and/or bulged caps. I'm suspecting a bad horizontal output transistor, or HOT. At the screen itself turns on meaning your flyback is good. I'm dealing with two D9200 chassi with missing/bad flybacks and those currently aren't available new right now.
      Being the first ever digital monitor produced, the chassis is bound to have some flaws. The first is the chassis using a crap load of capacitors, 70+ caps, and the second is if the HOT fails, it can take some ICs out with it. Not an easy chassis to start with for your first but I have faith in you.
      My projects: Motocross Go x2
      well I appreciate your confidence but I don't deserve it lol. i just sent the chassis to PNL for repair. I do not have the knowledge to repair that chassis nor do I have the tools for it. I learnt something in my little tinkerer carrier. if you dont have the right tools you will make more damages than good.
