rememberizer
I've installed CRT Emudriver on my PC and into my Aero City MS8-26 for Retroarch and online fighting games, and it's actually working great for that purpose.
Unfortunately, it's not perfect. I'm getting faint diagonal "waves" across my video image that occasionally disappear, as well as a horizontal band of faint static that scrolls upward.
The setup is:
Dell Vostro E7500 Core2Duo 2.96ghz
Radeon HD7450
THS7316 video amp, 75ohm termination on input, no termination on output. Powered by USB.
Cheap stereo amp fed with the 3.5mm jack. Powered by stock cab PSU.
The PC is plugged into the outlet on the back of the cab
I tried several things. Unplugging Audio does nothing. Powering the video amp using an external 5v PSU does nothing. Changing the video cable does nothing. Disconnecting the Arcade PSU from the jamma harness and power line reduces the diagonal waves, but the horizontal band remains.
Not that none of this happens when I use an arcade board or a Raspberry Pi. What do you guys do to fix this for your CRT Emudriver setups? I'm pulling my hair out trying to get a good image from this, might just scrap this whole project if it doesn't work out!
The setup is:
Radeon HD7450
