chacal231077
France
Hi! :)
I would like to know the reference of the following component ^^
Resistor Arrays DIP RSA1 & Diode schottky on D1,D2,D3
Thanks ;)
Do you want to know what they do?? Or do you need to replace them??
T.
The diode is easy.. there on ebay etc.. just serch for SR140.
The resistor network... i'll have to remove one and test it. Normally they have one common leg, then each other pin is the other side of the resistor.
Thank you ;)
Hi !
I tested the NETWORKS RESISTOR
2nd pin 10.56
3rd pin 8.78
4th pin 7.90
5th pin 7.46
6th pin 7.24
7th pin 8.01
8th pin 7.02
So it's a 10K ohm ?
