The Jassifier
    • The Jassifier
      I was going to wait for the final version (1.6) PCB to be built, but I decided to just go ahead and release this now! :D
      This device is NOT endorsed or recommended by the creator of the Jammafier!
      Its purpose/my intention was to provide cheap (currently @ 14.40$ per-PCB-build price) arcade PCB video attenuation to use with OSSC's SCART port.
      Designed by @Frank_fjs using as many thru-via components as possible for ease of assembly.
      Beta tested by @wigsplitta and myself (a 3rd beta unit was also sent to @rewrite but I never heard back from him).
      It can be ordered here at OSH Park, BoM can be ordered from Digi-Key.
      Pictures of the beta (1.2) version/test with a Jammaifier+OSSC in a Taito Vewlix Diamond (PCB on the right).
      The 1.2 beta revision had optional power input via mini-USB, it has been removed from 1.6
      Recommended (what I'm using with this setup/OSSC) accessory: etim nesrgb/2600 rgb adapter
      First batch orders closed:
      @KingSopz 2x
      @ekorz 2x
      @jassin000 2x
      Potential future pre-assembled orders based on mutual expressed interest, however project is best when you DIY. :)
      RGB: RECO v2
      invzim: Jammafier v1.6b, Tri-Sync Helper
      The post was edited 7 times, last by jassin000 ().
    • Arcade video attenuation to SCART levels, suitable for OSSC's SCART port.
      NO sync processing only attenuation TTL/75ohm output (supports Taito F3 work-around).
      RGB: RECO v2
    • the Goat wrote:
      Basically the video (RGBS) signal path from a supergun, broken out into a separate PCB?
      If you have a Jammafier you can't connect it directly to a OSSC because Jammafier isn't processing the video portion at all.
      The signal is too strong/colors too bright/washed out, and its unsafe for the OSSC.
      CPS3 test menu when connected directly to the Jammafier (notice how bright/washedout the colors are/no separation lines A~F)
      Officially Zim intends you to use a Tri-sync Helper to attenuate the video signal, I see two problems with that design...
      1. TSH process/regenerates the sync, altering it (PCBs that never needed special OSSC settings now need them, and some can't ever be adjusted to work like Midway)
      2. TSH outputs via DSUB (if you use the DSUB connector of the OSSC you can't use its onboard low-pass filtering options)
      Sync shouldn't be processed at all (not with OSSC it hates that)! Only attenuated with TTL/75ohm optional output to support Taito F3.
      PARTY MAN X wrote:
      I ran a brief test without the tri-sync helper and the OSSC was able to sync correctly which leads me to believe it's the tri-sync helper's sync processing that's acting up. I don't suppose there's a way I could bypass the sync processing while getting the attenuation, is there?
      This device is IMO the perfect solution for arcade PCBs when used with the OSSC via Jammafier (or custom SG DIY project).
      RGB: RECO v2
      The post was edited 15 times, last by jassin000 ().
    • meybarra wrote:
      What are your thoughts on using this to attenuate video output from an Extron Crosspoint to the OSSC scart input
      Don't let the DSUB connector dissuade you (is was selected to easily connect with the Jammafier) it can be used for any supergun like application.
      As pointed out by @the Goat this is basically the video only portion of a supergun design.
      Input looks like this...
      RGB: RECO v2
      The post was edited 6 times, last by jassin000 ().
    • New
      Sorry for the late reply, work's been a bit busy the past few weeks!
      I've given this a good few hours of play and am happy to confirm that it works nicely in my JAMMAfier - OSSC - Vewlix C setup. (I'm using a RGC 8pin din --> rgb scart cable)
      I've tried various boards and not had an issue with anything.
      I need to re-read up the PM thread, but I was under the impression that the concerns Zim had about the original design were addressed, and his and other peoples recommendations were implemented into an updated design?
    • New
      @Frank_fjs has done in my amateur view a fantastic job, with thicker traces and ground pour.
      I welcome any pros to chime in and make recommendations/criticisms however so we can continue to evolve the design.
      I wanted something optimal for folks like us (aka VLX owners who play JAMMA boards with a Jammafier+OSSC combo).
      This isn't about egos for me, optimal is optimal.
      RGB: RECO v2
    • New
      Im all for it being optimal :)
      Are we still planning to do one that mounts over the taito scaler?
      Another thing Ive been tinkering with is mounting supports for jammafier, ossc, jassifier etc. and I guess will need some type of switcher.
      Wanted: PCBs - Batsugun, Battle Garegga, Battle Bakraid
      Other stuff - 19" Monitor/chassis and/or WG K7000 Chassis
      Vewlix Shipping Brackets (2x sets of the red ones would be nice)
      High End Headphones/Desktop Headphone Amps/DACs as well.
      If you have any of these for sale/trade let me know :thumbup:
    • New
      Well the Jassifier when used directly with the Jammafier needs no additional mounting... ie the connector we selected for the 1.6 revision plugs right in just like the TSH.
      Also like the TSH it draws power from the Jammafier so it requires no additional connections, it simply outputs attenuated MD8 at SCART levels.
      As for the overlay design I'm still all about it, and this time I have the complete design to offer you so it can be adapted modified into whatever you need.
      I always imagined a "pro" version that used SMD components making it far more compact in addition to the special shape to overlay with the OG Taito JAMMA kit.
      RGB: RECO v2
      The post was edited 2 times, last by jassin000 ().
