As this sega system is verry new ,lets open her up to understand what’s inside
From the outside it looks a bit like a ringedge 1/2
Uses a usb stick for sec chip
has a special jvs board ,almost like the Lindbergh has.
inside it has a normal ssd and uses a pretty low mem gpu as you have diff steps like ringedge 1 and 2 you have the NU 1/1.1 and the NU 2 all the same base hardware just higher GPU and Mem
you can switch it out depending on the game and uses 8 up to 16Gb or internal ram . I have to check the cpu yet.
this system is running initial D zero
Using Sega jvs i/o type 3 and/or the extended I/o for racing
