I have a Vewlix FC with the following setup for the controls:
To try to isolate where it's coming from, I've tried the following:
EDIT 2020-08-07:
Solution found!
The part is just an audio ground loop noise isolator. By adding it in-line between my laptop and the amp, the JVS data noise is no longer picked up and the speakers stay silent even when the amp is all the way up.
It also works in your car if you have a line-in and get noise from having your phone/DAP charging at the same time
- Taito JVS IO (v2)
- JVS-PAC2
- Thinkpad T430
- JVS-PAC2 connected to laptop and IO, laptop connected to amp: Noise (standard setup)
- JVS-PAC2 connected to laptop and IO, laptop not connected to amp: No Noise (retested, I was wrong)
- JVS-PAC2 connected to laptop and IO, a different laptop connected to amp: No noise
- JVS-PAC2 connected to laptop and IO, headphones connected to laptop: No noise
- JVS-PAC2 connected to laptop but not IO, laptop connected to amp: No noise (sound from laptop works fine)
- JVS-PAC2 connected to IO but not laptop, laptop connected to amp: No noise (JVS-PAC2 had no power)
- JVS-PAC2 connected to laptop and IO, laptop connected to amp, testing with headphones dangling nearby: No noise in headphones
EDIT 2020-08-07:
Solution found!
