I'm really happy with the updates today.
We fixed some problems with the old version PCB, so, i ask, please, everyone, check the schematics and PCB, please!!!
Thanks USB2DB15 team!
[0.14.2] - 2020-10-09
Added
- Added analog nub support for Xbox One controllers.
- Added `debug.h` to control serial output.
Changed
- Fixed an issue with button mapping surrounding Xbox One and Xbox 360 controllers.
- Files altered: `XboxOneController.cpp` `XboxUSBContrtoller.cpp`
- Fixed an issue surrounding PS3 analog support.
- File altered `PS3Controller.cpp`
- Removed the temporary `#define ENABLE_SERIAL` as it has been superseded by `debug.h`
PCB 1.1
Changed
- DB15 on schematic was right, but the footprint was inverted, forcing to solder the connector pins on the top side, it's now fixed.
- LED pin is now on D8 pin, so can reflec the code.
- We are now using a 3 pin DUO COLOR LED (center cathode) for a adicitional USB status,
so if there's any USB controller inserted and working, one LED color will be on, else, off.
- Reset eeprom memory circuit inserted
- PCB was downsized
