ZoomBoy
Oshawa
Hi, bought an Extron RGB 202 Rxi to connect my Sega Naomi to my D24 BVM. I've discovered the INPUT on the Extron uses a non-standard Male DB9 instead of the standard HD15 VGA.
Does anyone know, or have available a cable that goes from standard VGA to Female DB9?
Yeah I wasn’t sure if these adapters would work - as I had read one person tried with no luck. At least they’re cheap enough to give it a shot.
my answer to anything cable related - make one.
it's the only way to be sure not only that it's wired right, but that it uses decent cable and is the length you need.
(it will usually cost less too :) )
