Time Soldiers repair log and 'ALPHA-INPUT84/87' reproduction
    • Time Soldiers repair log and 'ALPHA-INPUT84/87' reproduction
      Bought on eBay from the States a Time Soldiers PCB which arrived to me some days ago (by the way, thanks to 'coolmod' for his mediation and forwarding) :
      Auction described the board as “TESTED NOT WORKING-GARBAGE ON SCREEN-MISSING CHIP”
      The missing chip was actually one of four program ROMs:
      I programmed a blank EPROM and finally powered the board up.All I got was a partially dimmed screen in which I could recognize the power-on TEST which probaby failed since the board kept resetting:
      As usually I do, I started my troubleshooting with a visual inspection.Board was in very good shape but flipping it I noticed scratches on solder side, some quite deep :
      A couple of traces looked really severed under the microscope and my multimeter in continuity test confirmed it :
      Patching the broken traces fixed board completely :
      The repair was pretty easy, just a quick fix hence it gave me time to look for something on the board to reproduce.The long custom SIL marked 'ALPHA-INPUT84' was a good candidate :
      This custom IC handles inputs and Time Soldiers, being a rotary joystick game, uses four of them (two for 8-way joysticks of both players and the other two the 12-way rotary joysticks).Later Alpha-Denshi games like Gold Medalist use a part marked 'ALPHA-INPUT87' that externally is identical but with slight internal differences :
      The two parts are not interchangeable but I was able to merge both designs in a single reproduction part: :
      Testing on PCB was successful on Time Soldiers PCB, all directions of both players worked with 8-way joysticks (could not test rotary because I don't have them)
      Another PCB and custom IC preserved!
      The post was edited 1 time, last by caius ().
    • caius wrote:
      Thanks for the list!Maybe not the most wanted reproduction but it's always good to have it in my opinion ;)
      The other parts on this board are quite good, all hitachi and stuff.
      With this input repro available it makes the hardware simple and easy to repair / maintain :D
      It will be used on many others too, the list is just what have seen over the years / common stuff.
      You almost seem sad that it was so easy ! :rolleyes: Who else would say "we'll it's all working but let's try to reproduce something, just for fun"
      amazing.
      Now you make me wanna find a board for my rotary joystick!
      Thank you !
    • Mrhide wrote:
      You almost seem sad that it was so easy ! Who else would say "we'll it's all working but let's try to reproduce something, just for fun"
      amazing.
      Ahahahah!Thanks.Well, we are not speaking about a 'CPS-A-01' or other full digital ASIC so the part was really easy (for me at leat) to replicate.Here 's the "naked part" :
      And I'm looking instead for a rotary joystick!it seems they are not really cheap and easy to find.
