Model 3 Racing games ..swapable?
    • Yes it it possible but model 3 is only model 3
      if you want to play model 2 in a model 3 cabinet and vice versa you are way out of your comfort zone here as it’s takes loads of wiring new motors etc
      for model 3 most of the times you have to switch the eprom for the force feedback depending on the game
      also some games use 4 way shifters other only u/down
      and some games have extra buttons etc. I think best way to play everything is to make a pc that runs model 2/3 etc and hack the steering wheel etc
      Ok that Sounds Good. So basically I can play all model 3 racers with that cabinet. For the eprom switching: how is that done exactly?
    • On the steering pcb you change 1 eprom that contains the ffb codec for that game .
      also remember that you have different steppings
      model 3
      step 1.0,1.5,2.0,2.1
      Le Mans and scud racer is step 1.5 so you only need to change the rom board (Scud race uses also a dedicated extra sound board ) so it’s all not that easy
      but if you want to play Daytona 2/ dirt devils/ eca etc those are step 2.2.1 so those will not boot on the 1.5 you need a dedicated cpu/video board to play those
      step 2.0 and 2.1 is the same just a newer revision
      I know it’s a little bit confusing but google model 3 first and learn about the steppings etc then proceed from there and what you want to play
      The post was edited 1 time, last by AMS ().
    • One thing to be aware of is that although Lemans is a Model 3 Step 1.5 game, Lemans 24 uses the older steering wheel motor + FFB boards that are found in games like Touring cars. It doesn't use the same steering wheel motor + FFB boards that are found in Sega Rally 2/Daytona 2/Scud Race etc.
      As far as I'm aware you won't get FFB when playing other Model 3 games in a Lemans cabinet, but, you can put Lemans in a later model 3 game such as Daytona 2 and get FFB. I have tested Lemans in a Daytona 2 cabinet and although it's basic the FFB works well, there's an option in the service menu to change the FFB setting.
      Images
      A French enthusiast has discribed a multibios setup for model 3 force feedback : rep-arcade.com/2019/02/sega-rally-2-multi-bios.html
