A simple adapter for rotating the DB15 joystick input 90 degrees right to play vertical titles on standard TV's.
The game will still play horizontal but now the joystick will match movement directions.
Built with a kit available from RSOnline or you can solder your own with a DB15 to DB15 gender changer shell, 1 male and 1 female DB15 solder cup connectors and some wire.
The kit comes with crimped wire connectors so is quicker and easier to put together.
RSOnline Kit: https://au.rs-online.com/web/p/d-sub-connector-accessories/3822768/
Black gender changer shell from Digikey: https://www.digikey.com/product-detail/en/norcomp-inc/957-015-010R011/957-1511E-ND/1632194
Pinout diagram below as well as photos of the actual adapter to help people build their own.
Pinout
Adapter wiring top
Adapter wiring bottom
Adapter in shell
Adapter in use
Pinout
Adapter wiring top
Adapter in shell
Adapter in use
