Hypnotoad
Uk
Just a quick one guys If anyone can help, when I sent the settings I want in the test menu ie: set to free play and difficulty selection, once I turn it off and back on again these settings are lost and I have to re enter test to configure again. Seems odd and suggestions or is this a usual thing
That is not normal, my settings all stay fixed. I believe there is a battery under the plastic cover on the motherboard, I would assume that's what stores settings while the game is powered off, but I've never actually opened mine to look at it.
It only saves if you continue to choose the same region. If you have a rev1 board there is a battery under the white plastic thing, but that is unrelated.
If you have that battery I highly recommend you snip it off.
Don't want damage from it leaking onto the PCB and it dose 100% nothing (actually it powers some SRAM that isn't used by any game).
