DeWitt
Germany
Hello everyone,
I'm currently working on a universal JAMMA adapter board which I can use to build rapid prototypes instead of designing multiple adapters for my needs. I started doing that and it got really time consuming...
So here is my current progress:
JAMMA adapter mainboard
The extension boards are designed to fit on top of the "mainboard":
Small extension board
Big extension board
The holes that connect bottom and top need to have exactly this spacing. I have an audio amp that fits exactly.
All my work is based on a design of @Frank_fjs (Jamma Fingerboards) and my gerber files will be free to use when I'm finished.
Feedback is highly welcome ^^
PS: please be gentle. Its my second time that I used a PCB software...
Second time using PCB software, my ass. You are the Muad'dib of EasyEDA.
He shall know your ways as if born to them.
-Frank Herbert, from the Dune Chronicles
Thank you very much for your kind words!
It is actually true it was the second time, it took me forever! I posed my first PCB in @Frank_fjs Jamma Fingerboards thread.
I really need to work on understanding this software better! I did a lot of copy & paste. Positioning and spacing was done by hand and not really exact. There should be tool support, I haven’t found it. I also switched between mm and inch while editing, this messed up a lot of spacing. But in the end I’m happy with the result!
My superpower is patience, that’s all, no magic!
