Thought I would throw up a thread so if people want to post their setup, maybe there is a pattern and also somewhere to post/find the solution IF found..
Mine is running on a rev 4 Marvel v Capcom (pal G) board, everything works fine except really annoying crackling that is almost constant, but more noticeable when less audio/action. The crackling is present with MvsC too but only with the multi, if I put my original chips back on it works fine (same A and B boards).
I am running my audio through the stereo RCA outputs.
I also have a suicided Tower of Doom (Pal f) board that I was gong to try out next, it is a rev 3 so not expecting a different result but it is the only other board I have to test out..
