goguelnikov
nice job
can you share your setup ?
I would like to see a write of it so I can compare it to the Version 3/4 version's flash chips.I have now cracked the MSP55LV100S chip, turns out it's an oddball, 2x 512Mbit 8-bit cores (id matches Spanison S29GL512P) arranged as one 16-bit chip So I can read,erase,write etc. and have a confirmed good pinout, can write up the details if there's any interest.
Looks like another annoyance will be scrambling, have only dumped the S rom so far, some trivial-ish scrambling which i've cracked, but that's the low-hanging fruit, the others will most likely be trickier...
If you're talking of the music disappearing but sound effects still working it's also present on the multicart I got. P ROMs pass the CRC check but it could well be a bug in the Z80 code.Could you share the files for Nightmare in the Dark, please? There's a sound bug in the game when played on original hardware (Mame doesn't have it), but apparently it's been fixed in some multicarts (and possibly genuine carts too). See here:
Games with Issues
That's not it. The sound bug affects the jump sound effect, it sounds distorted. It happens every time you jump. It's really obnoxious.If you're talking of the music disappearing but sound effects still working it's also present on the multicart I got. P ROMs pass the CRC check but it could well be a bug in the Z80 code.
NITD V/M are good, V's crc match mame bootleg set, which itself is the official set (single v) cut in two.Could you share the files for Nightmare in the Dark, please?
It's the Fujitsu MSP55LV100S (128MB/1Gbit sop70) chips i'm working with, so anything else using those I can now dump and reprogram.I hope this dumping technique can be used with the "old" cps1 multigame with the super pang hack (it was a stand alone game but lost to time).
yes it sounds scratchy/staticy it's present on my original cart and very annoying.That's not it. The sound bug affects the jump sound effect, it sounds distorted. It happens every time you jump. It's really obnoxious.
At this stage it's only really fixes, eg. for NAM I could quite easily erase the duplicated V and replace with the correct one. I guess something like changing a hack/clone of a game to the official (or different hack) should be possible too.I've been wanting a way to change the games on my 161 in 1 cart for a while too.
Humm... Neither my OG cart nor the cheap 161 in 1 does that. However I can reliably trigger a bug causing music to stop if I throw flames at a chest and just before it disappears I pick it up and a diamond in the same frame.That's not it. The sound bug affects the jump sound effect, it sounds distorted. It happens every time you jump. It's really obnoxious.
