Hi,
A friend had a problem with his CPS 2 :
- A board japan + Convert Jap Progear (same problem with a convert of Mars Matrix)
---> After few hours of run (attract mode) the sound is near to zero. After checking the test menu, the sound is still to 39. When another pcb is plugged (mvs as example) the sound is ok. When it's plugged again with CPS2-> same problem .
After a night without run, the sound is back for good until ... few hours ... and ... same problem.
Do you know the cause of this problem? Maybe a capacitor on the A-board heats?
Thanks a lot guys!
Thanks a lot guys!
