Thats your reset line. If you are updating the firmware on the multi to the latest with keywriting you need to remove that blue wire and install your keywriting wires after updating the firmware.Ok so what is the blue wire currently installed on CN9?
I would, dont understand why that person used all that hotglue unless they messed up something and they have the hotglue holding things together. I have had properly installed kits shipped from japan, europe and never had an issue with them not working, not hot glue either. Plus Mitsu is kinda close to ya, so shipping would not be bad, pretty quick.I just looked up how to update the firmware. Looks like a nightmare. So basically I’d need to send this thing to mitsurugi ?
If it is working as is, just leave well enough alone.Thanks guys. I’ll think about whether encrypted roms is really important enough to me to risk it
There are a few blokes known to LOVE hot glue. Ever heard of drakkon?I would, dont understand why that person used all that hotglue
in that case I assume that cover beaked pin.I would, dont understand why that person used all that hotglue
I would remove all that hot glue, put in the wires and dont glue it back together - it should not be necessary.Hot glue is super easy to remove by simply applying isopropyl alcohol and letting it sit for a bit. After that it'll lift off with ease.
